 da sunlova kit bafang anteriore
job Inserito il - 19/02/2010 : 17:46:46
Per caso mi sono imbattuto in questo kit con motore bafang anteriore venduto da http://www.sunlova.com , a 353£ corredato di tutto compresa batteria al litio 36V10Ah su portapacchi dedicato.
Features include:
Specially designed for European market
Model Type: Electric bike conversion kit
Triple Riding Modes: Pedal Only, Pedal Assisted and Full Motor Power
Electric Motor: 8Fun 36V 250W intelligent No Hall brushless hub motor,
can be fitted with Disc brak as well as V brake
Motor Controller:No Hall 36V 250W, with movement sensor
Brake levers with cut off switches
Twist grip with battery indicator
Battery Rack: You can lock your battery on the rack
Max Speed: 15MPH (UK Max)
Max Riding: Up to 35 Miles(Depending on the rider's weight)
Battery: 36V 10Ah Li-Ion battery with power Key - to turn on/off power and
lock/unlock the battery onto the rack.
Battery life: Recharge in 4 to 6 hours > 1000 recharge cycles
Wheel Size: High quility 26" wheel rim fitted with motor
Extra Aluminum box for mounting the controller box onto the frame
New technique No Hall Motor and Controller, the most reliable ones in
the market.
gigi35 Inserito il - 19/02/2010 : 18:12:11
motogigio73 ha scritto:
£354.99
Availability 5
Warranty 6 Months
Shipping UK Only
Postage £14.
avevo visto questi kit qualche mese fa quando ero andato sul sito sunlova a vedere le pieghevoli quindi immagino che finita la quantita' in vendita ne tirino fuori degli altri,per la spedizione io ho visto uk/eu (inghilterra/europa)
motogigio73 Inserito il - 19/02/2010 : 18:01:39
http://www.sunlova.com/Detail.aspx carina anche questa pieghevole
motogigio73 Inserito il - 19/02/2010 : 17:57:51
£354.99
Availability 5
Warranty 6 Months
Shipping UK Only
Postage £14.
