 nuove mtb flyer. Bosch!!
Fede
373 Messaggi
Inserito il - 01/09/2014 : 15:01:19  Mostra Profilo Invia a Fede un Messaggio Privato
http://flyer-emtb.com
http://www.elektrobike-online.com/news/e-bikes-und-pedelecs/flyer-bringt-2015-drei-neue-e-mountainbikes-und-zwei-urbane-pedelecs.1218898.410636.htm (traslate):
For the 2015 season, Flyers has three e-bikes in the program. The models Flyer Uproc6, Uproc3 and Goroc based on a specially constructed for E-bikes frame. The aim was to provide true-e-bikes on the legs and not easy to develop only a mountain bike with a motor.
Priced start the Flyers off-road pedelec with the Flyers Goroc for 3,199 euros. The hardtail mountain bike flyer Goroc running on 27.5 inch tires and will allow the used 12 millimeter thru-axle Steering a stable and offer a stiff rear triangle.
The next price level is the Fully Flyer Uproc3 for 4,199 euros. According to the manufacturer, the full-suspension MTB-E should feel at home in any terrain and convincing maneuverability, stability and quiet Bosch-performance driving.
The Flyers Uproc3 has an all-mountain / trail frame geometry and has a rock Shox Monarch chassis with 130 millimeters damping. At the front, provides the fork Rock Shox Revelation also 130 mm of travel. The chain guide of the flyer Uproc3 comes from NO pulleys, thereby noise and wear are to be minimized.
Gears and disc brakes are from the XT groupset from Shimano. Optional Vario-seat post is available that allows you to change the saddle height while driving.
Enduro-top model flyer Uproc6 for downhill fans
From 5,499 €, the top model flyer Uproc6 costs. This e-Enduro is constructed departure oriented in the first place. Whopping 160 mm travel offer the Rock Shox Pike fork and the shock Monarch Plus motorized bikes.
The wheels are from DT Swiss and combine a 27.5 inch wheel up front and a 26-inch wheel at the rear. This combination will allow a stable flyer Steering pedelec bikes and produce optimum traction during braking and cornering.
Like the Uproc3, the Flyers Uproc6 has a chain guide without pulleys. A Vario-Support with handlebar remote control is standard equipment in which over 5,000 euros expensive E-Enduro.
Furthermore, the E-Flyer Uproc6 mountain bike has a Shimano XTR gear shift with 11-gears.
- Turbo Levo 2019
- Brompton S 6M
- Salsa Vaya
- Univega Vision Impulse 2.0
