 36v12Ah led=cuanto chilometri con 9continent?
kocileiu Inserito il - 05/06/2008 : 18:28:09
i have a 36v12Ah led battery. if i buy a kit nine continent and put it on a bike (28 or 26 inches(?)) what do you think how many kilometer i can drive? i dont have many hills, 2x24km with flat and about 10 small hills between 20m and 50 m high. Do you have a similar experience with nine continent? thank you
ho una batteria (piomo(?)) 36v12Ah. con un kit nine continent che pensa lei? posso fare 2x24km senza problema? ho solo dieci piccole montania con 20 o 50 m di altrezza(altitude?). grazie
joffa Inserito il - 05/06/2008 : 21:44:56
Messaggio di kocileiu
Hi, and welcome !
I think with such a battery you can be able to run up to 45 km max if you don't waight over 100 kg. and your tires are well in pressure and not too large at soil level.
It even depends on how much you assist the engine...:)))
Then, a new battery is more capable of an old battery and different type of batteries have got different types of base residual capacity, keeping in mind even that brushless controllers need a minimum voltage in order to work. Under that, they stop.
elle Inserito il - 05/06/2008 : 20:54:01
ciao kocilieu, penso di sì se aiuti un po' pedalando
qui dido ha fatto 50km in montagna con un nine continent - le batterie 14ah non erano esaurite: http://www.jobike.it/forum/topic.asp?TOPIC_ID=1913
I think that you can - not without pedaling though
