 Vendo 2 batterie al litio per overboard
qqaa11 Inserito il - 26/09/2019 : 02:11:45
VENDO 2 batterie per overboard 20 celle 36V 4.0Ah-4.4Ah
1 anno di vita perfettamente funzionanti.
Prezzo 50€+sped (per la sped. facciamo a metà)
CARATTERISTICHE:
Voltage : peak - 42V, working - 36V ,Cut-off voltage: 25V
Nominal capacity: 4000mAh / 4400mAh
Charging ways: Constant Voltage constant Current
Size: about 135*85*55MM
Composed Type :Charging panel(10S2P)
Components: 2200mAh Li-Ion 18650 Battery
Applications: Electric Unicycles,e-bicycles,e-scooters
Overdischarge protection: YES
Overcurrent Protection: YES
Power: 158WH
Standard Discharge Currents: 4.4A
Max.Continuous Discharge Currents: 15A
Standard charge current:2A
Max charge current:3A
Approved: CE,CCC
Cycle life: More than 1000 times
Input Voltage: 42V,CC/CV
39,08 KB
Questa pagina è stata generata in 0,02 secondi. Versione 3.4.06 by Modifichicci - Herniasurgery.it | Distribuito Da: Massimo Farieri - www.superdeejay.net | Powered By: Platinum Full - Snitz Forums 2000 Version 3.4.06
