| jumpjack |
Inserito il - 22/04/2013 : 21:03:39 Ultimamente mi sono dato al collezionismo: raccolgo tutti i siti che trovo che vendano batterie LiFePO4, possibilmente A123, ma che abbiano sede solo in Europa.
Questi sono i miei "ritrovamenti" ad oggi: http://www.ev-power.eu/?p=p_33&sName=home&src=diy http://www.hobbyking.com/ http://litrade.de/shop/ http://3xe-electric-cars.com/index.php http://koorteh.com/ http://wh.newelectric.nl/ http://www.der-schweighofer.at/ Drop-in 12V (5Ah/10C/100Euro) http://www.scottcountry.co.uk (only 12V/300Euro) http://www.vision-batt.com/product_v...9&tid=20#links (only manufacturer?) http://www.energaitaly.it/ (italy) http://shop.lindinger.at/ (austria) <<-- A123 LiFePO4 High dicharge cells http://www.miniplanes.fr/ (only small voltage packs) http://www.topmodel.fr/ (no LiFePO4) http://www.weymuller.fr/ (no LiFePO4) http://myhelis.com/ (only small voltage packs) http://www.helidigital.com/shop/ (no LiFePO4) http://www.ashobbyracing.it (no LiFePO4) http://aerobertics.be/products.php?cat=11(only small voltage packs) http://www.voltronic.de/shop/product...-1100-mAh.html (weird site) http://www.smallbattery.company.org....IP26650-FT.htm http://www.lithiumstorage.com https://www.distrelec.ch/lifepo4-akk...ems/apr18650m1 (only A123) http://www.maurelma.ch/shop/index.php?list=WG139 (expensive) http://www.ripenergy.ch/ http://www.accu-24.de/ (Only 12V LiFePO4 packs?) http://www.akkukaufhaus.de (only LiFePO4 by HOLE, low discharge rate?) http://www.wattabox.fr http://www.cycloboost.com (48V LiFePO4 packs, no cells) http://piles44.com http://www.pilesbatteries.com http://comparerc.com/ http://www.parkflyer.ru/ (comparisons US/RU/EU) http://www.maximus-racing.com (A123, only packs?) http://fr.eannu.com/lifepo4.html (Sites comparison) http://www.hadi-rc.de/epages/es12512...s/z1-A123-2500 http://comparerc.com http://www.eflug-technik.de/akkus/li...23systems.html http://shop.lipopower.de/Akkus-Batterien http://shop.strato.de/epages/6133307...23_ANR26650M1B http://www.brusa.biz/index.php?id=189
Ok, ora sono un po' frastornato... :-) A me servono 20 celle LiFePO4 ad alta scarica, almeno 50A continui, ma a bassa capacità (anche 2000 mAh bastano), però mi dicono che non tutte le A123 da 30C sono uguali, alcune sono "farlocche": come distinguerle?
Secondo voi su quale sito mi conviene comprare?
| 7 U L T I M E R I S P O S T E (in alto le più recenti) |
| Barba 49 |
Inserito il - 23/04/2013 : 09:57:13 Ci sono le vecchie da 2200mAh e le nuove da 2300mAh, per il resto le caratteristiche sono le stesse. Tra l'altro le 26650 A123 si possono saldare anche a stagno senza problemi, la cosa è ammessa anche dalla stessa casa produttrice che mette in commercio le apposite linguette da stagnare.  |
| jumpjack |
Inserito il - 23/04/2013 : 09:52:23 |
Il primo fà riferimento alla versione B che è leggermente migliore. Entrambi te le possono fornire con le linguette.
Cioè esistono varie versioni? Dove trovo qualche info? |
| T4R |
Inserito il - 23/04/2013 : 09:08:31 Guarda qui sono affidabili ed in Europa: http://www.batt-energy-shop.de/product_info.php?info=p318_a123systems-lifepo4-anr26650m1b-akku-3-3v-2-5ah.html&XTCsid=8f64ea279418c77685b8520c23958a21
http://www.linergy-shop.de/product_info.php?info=p494_a123-anr26650-m1a-2300mah-lifepo4-zelle-a-version.html
Saluti Pino |
| jumpjack |
Inserito il - 22/04/2013 : 22:55:27 Ma sono senza linguette, come si fissano quelle "barrette" senza squagliare la batteria? |
| Barba 49 |
Inserito il - 22/04/2013 : 22:18:48 Alcuni amici le acquistano qui: http://www.flymodelcomponents.it/shop/home.php?cat=426
Sono originali e durano una vita... Loro ci fanno volare i modelli, quindi le spremono veramente al massimo.  |
| jumpjack |
Inserito il - 22/04/2013 : 22:13:22 | MilleMiglia ha scritto:
Ecopolis ha delle celle A123 32113 da 4,4Ah...
Immagino che costino troppo per il mio progetto, costano già troppo le 2200 mAh. |
| MilleMiglia |
Inserito il - 22/04/2013 : 22:04:06 Ecopolis ha delle celle A123 32113 da 4,4Ah... |
