 Link interessanti
 Carica Veloce per Li-ion?Sembra ci siano novità...
digitalfranz
174 Messaggi
Inserito il - 13/03/2010 : 19:53:56  Mostra Profilo Invia a digitalfranz un Messaggio Privato  Rispondi Quotando
http://www.engadget.com/2010/03/13/scientists-discover-method-for-rapid-charging-li-ion-batteries/
saluti!
Frisbee Euro 7
MTB Crystalyte 4006 36V anteriore
NineContinent HS800 48V - Batteria PING BATTERY BMS V5 48V15Ah
Inserito il - 13/03/2010 : 20:03:04  Mostra Profilo Invia a jumper un Messaggio Privato  Rispondi Quotando
dal medesimo sito:
Modern gadgetry (you know, as opposed to "ancient gadgetry," such as the abacus and the hour glass) lives and dies by its batteries, so it's no surprise that lots of time and effort is spent researching both wacky alternatives to the tried and true power cell, as well as ways to make existing cells better. Among the latter, Nikkei is reporting that Eamex in Osaka, Japan, has developed a lithium-ion battery that will last some twenty years of regular use -- that's 10,000 charges! The secret to the long-lasting lithium-ion? In current designs, the tin that's used for the battery's negative electrode weakens through continual charging and recharging. The new design, however, calls for tin-coated resin that stabilizes the electrode and prevents deterioration. Why didn't we think of that? Look forward to seeing these exciting, new batteries debut in electric scooters sometime this year
