 Pieghevoli
 gruber assist brompton
Mario Sol
729 Messaggi
Inserito il - 16/11/2009 : 18:46:39  Mostra Profilo Invia a Mario Sol un Messaggio Privato
ho scritto alla gruber assist per sapere quale compatibilità / incompatibilità esista con la famosa pieghevole londinese
scott diy urban cargo
brompton M6l 07-09-2009
inutilizzata
cinelli vigorelli 9-05-2026
Inserito il - 16/11/2009 : 18:52:34  Mostra Profilo Invia a elle un Messaggio Privato
scommetto che non si può - ma se perdo la scommessa mi fa piacere
Mario Sol
729 Messaggi
Inserito il - 16/11/2009 : 21:13:28  Mostra Profilo Invia a Mario Sol un Messaggio Privato
hai ragione la scatola movimento della b e il tubo reggisella sono sfalsati :(
inutilizzata
Mario Sol
729 Messaggi
Inserito il - 17/11/2009 : 15:48:18  Mostra Profilo Invia a Mario Sol un Messaggio Privato
ecco la gentile risposta:
Dear Mr. Sol,
we are pleased about your interest in our product. In addition you can find our product brochure with information and prices about the GRUBER Assist and our complete bicycles.
GRUBER Assist is an ultra-light drive for bicycles, invisible built into the seat tube of the bicycle. The auxiliary drive supports with 200 Watt engine power (100 Watt Output) and weights just 900 grams (plus 1 kg battery).
For installing the GRUBER Assist into your bicycle, please note the requirements for the bicycle frame:
* Aluminium or steel frame
* Straight, continuous seat tube
* Seat tube inner diameter of 31,6 or NEW 30,9 mm
* Shimano Hollowtech II crankset
* Seat tube should be as central as possible on the bottom bracket
* Minimum length of 62 cm from the middle of the crank to the saddle or 57 cm at a shorten seat post
* Installation by a certified GRUBER Assist dealer
As far I could see in internet, Brompton bicycles are folding bicycles. In this case installation usually is not possible, because the motor is in the seat tube (length 22 cm) and in the seat post there is the electronic control. So you can’t fold the seat tube anymore.
On our homepage you can find 3 spots what explains the GRUBER Assist exactly: http://www.gruberassist.com/english/downloads/spot-gruber-assist/
For testing we have a special offer: You can test the GRUBER Assist here in Austria. 2 nights in Ellmau incl. GRUBER Assist test bicycle cost € 100,00. And if you buy the GRUBER Assist in our company, we credit the amount to you.
Please note, that the GRUBER Assist has not installed a blocking. For example in Austria an E-Bike needs a blocking at 25 km/h, otherwise you cannot drive legal on a public street. If you want this blocking, please let us know this with order. A later installation is very complicated and more expensive.
For further questions don’t hesitate to contact me!
Yours sincerely
Julia Timmerer
Assistenz der Geschäftsführung
Betriebsurlaub 21. Dezember 2009 bis 10. Jänner 2010
Gruber Antrieb GmbH & Co KG
Brixentalerstr. 51
6300 Wörgl
fon: +43 5332 70317
fax: +43 5332 70522
__o
_\ <,
(_)/(_)
mailto:timmerer@gruberassist.com
inutilizzata
7772 Messaggi
Inserito il - 17/11/2009 : 18:02:57  Mostra Profilo Invia a job un Messaggio Privato
meglio così. Non trovo adatto il gruber per la brompton, poco potente, basso rendimento, e pure rumoroso .
Mario Sol
729 Messaggi
Inserito il - 18/11/2009 : 20:24:32  Mostra Profilo Invia a Mario Sol un Messaggio Privato
vedi però job che anche tu che hai preso il meglio allo stato dell'arte dell'elettrificazione brompton hai notato delle piccole alterazioni dell'equilibrio della londinesina, caspita ma qualche ingegnere che
1 restringa un bafang alla larghezza della forcella originale brommie e
2 usi il reggisella e magari
3 la sola itchair come portabatterie
farebbe qualcosa di interessante imo
inutilizzata
ger
518 Messaggi
Inserito il - 18/11/2009 : 22:13:12  Mostra Profilo Invia a ger un Messaggio Privato
volendo si potrebbe utilizzare questo per le pieghevoli:http://dpxsystems.com/ProductDetail.aspx?ID=184
c'è anche il kit:http://dpxsystems.com/ProductDetail.aspx?ID=198
Dahon Cadenza
maurice74
1408 Messaggi
Inserito il - 19/11/2009 : 06:12:12  Mostra Profilo Invia a maurice74 un Messaggio Privato
Se vendessero brompton come vendono auto gli ingegneri si attrezzerebbero...con queste scale credo sia impossibile utilizzare qualcosa di diverso dall esistente...
stefno
614 Messaggi
Inserito il - 19/11/2009 : 12:15:51  Mostra Profilo Invia a stefno un Messaggio Privato
peccato, perchè il reggisella della brommie è molto capiente come sezione e molto lungo.
